JenniferK
Hi,
I might be missing the obvious, but I've noticed posts with links to ffxml files which I assume are either filters or parts of filters. How am I supposed to use/incorporate them? Or are they only "for" serious coders or people with high end versions of Filter Forge?
In your web browser, you can click on the .ffxml link. At that point it should allow you to open the file in Filter Forge. The file is placed in the My Filters folder (near the bottom of the upper left pane) and should run at that point. One caveat: you can't run a FF9 filter in FF7 for example.
The code may be experimental, so be aware of that too.
if your web browser does not open it you can also right-click (windows) on the link and "Save as" to your desktop or where ever you download to and then open that file you just downloaded.
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
21 unregistered users.
