Anine
Will Filter Forge 10.0 Professional Edition plus lifetime upgrades work with any previous version of Professional or only for version 10?
Or in other words will any version of Professional Edition plus lifetime upgrades work for Professional 10?
I may not understand correctly your question, but do you mean if you can use in FF 10 ANY filter from any previous version available?
With Filter Forge 10.0 Professional Edition you can use ALL of the filters available in the filter library because it is compatible with all the previous versions.
The upgrades of lifetime will be for example, version 11, version 12, etc. because all the updates for FF 10 itself are included free until the next new number version appears.
So if you buy the lifetime upgrade you will never have to worry about any problem with any version as you will have all of them when they may be released and available.
Filters: 714
Yes, if you bought an older version of Filter Forge Professional Edition and you have also the Lifetime Upgrade, you can download Filter Forge 10 Professional Edition and use it without any other cost.
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
22 unregistered users.
