Please, How to batch process individual Photoshop layers applying a FF filter preset to each one of the layers and then save it?
I have 65 layers with different shapes in each layer, so I would like to apply the filter preset I want to each of the layers
1 - Load the layer into FF
2 - apply the filter preset
3 - Send the result to Photoshop again
4 - select next layer and go to point 2
I wonder if this can this be done using Photoshop actions? I know how to make actions, but do not know how to make it select the next layer. I have tried it but the action I made only processes just a single layer.
Do you know a possible way to do this ?
I do not think that any of the available external tools for FF could work, as they only work together with FF and not as a plugin
Thanks very much for any possible help as I can not load manually each one of the 65 layers into FF.
This is for PS7, but it describes keyboard shortcuts to use when recording actions involving layers (3rd response):
select Next Layer
Thanks very much Rachel, I did not know that you can use shortcuts for recording actions, so I will try it and see if it works for what I need.
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
19 unregistered users.
