Kevin Worth
O.K. this latest update does not have Filter Forge 9 in filters. This happened with the last update from Adobe! Is there a way to load Filter Forge 9 with the latest update?
Kevin Worth
In the 21.2.4 version of Photoshop, I copied the Filter Forge plug in folder from the plug in folder. I pasted this in the 22.0 plug in folder. Now Filter Forge 9 is working in the latest update. Hope this works for you if you are having problems.
