Ann B
Posts: 6 |
I'm sorry to ask what will seem a simple question to you all.
I have just purchased FF9 and I have been really thrilled with the effects. My confusion comes when I click on the presets showing pictures of daisies birds and fish etc, it (the preset image) simply sits on top of my original image and blocks it. I don't want an image of a fish on top of my rose. What am I doing wrong please. similarly; When I select a texture, the image of that texture is sitting on the screen but my image is not there. How do I blend the chosen texture with my image, or do I need to take it into Photoshop to do it? I have tried to find this out by google searches and looking in the forums tonight but can't find an answer. can any one please help me understand this. |
| Posted: July 10, 2020 7:18 am | ||||||
xirja
GMM, probably need to move this thread to General Discussion.
| Posted: July 11, 2020 9:31 am | ||||||
Posts: 3507 |
Ann B, welcome to the forums!
There are two kinds of filters in Filter Forge: effect filters are meant to modify an existing source image while texture filters replace the source image entirely. This is by filter author's design. Please check out the corresponding help pages: https://www.filterforge.com/more/help/...asses.html https://www.filterforge.com/more/help/...alImg.html |
| Posted: July 13, 2020 4:56 am | ||||||
xirja
Also to add to what GMM mentioned:
Sounds like you are loading an image into 'Selection': https://filterforge.com/more/help/Comp...tion3.html when you need to only load it into 'Image': https://filterforge.com/more/help/Comp...mage3.html or the reverse. If that isn't it then perhaps editing the filter: https://filterforge.com/more/help/Comp...ntrol.html Attaching an image capture example can help explain user troubles at times too. _____________________________________________________
| Posted: July 13, 2020 5:56 am | ||||||
This text comes from Need Help Understanding Filter Forge and there is even more information for beginners there and also Creating a New Filter with My Own Photo |
| Posted: July 16, 2020 3:25 am | ||||||
Ann B
Posts: 6 |
Sorry about the delay in replying but I have only just got back to my computer.
I have looked through your helpful replies and I think I understand what you are saying here. I will now go and have another go with this information on board. I tried to upload a screen shot of what I was referring to with the Attach a file browse button, but the image never uploaded. Oh well another learning curve. Thank you so much for taking the time to help me. |
| Posted: July 16, 2020 6:55 am | ||||||
I think that to be able to help you more specifically, please, tell what you are you doing exactly step by step, and where you have problem, so it can be seen where or what you are doing wrong It would be very useful to know what filter or filters you are trying to use, and how you use them, so it can be much better to help and guide you
If you see presets with the built-in images then this is a Effects filter and then you can use your own images The presets at first have always the default built-in images, to change them for your own images, it will depend on what filter your are using, there are two ways Of you are using the FF as standalone OPTION 1 - Go to menu File -> Open Image as seen here in the FF help. Using this way the final resolution of the result will be the one of the image you load, so you must put already the final size you want If using this your image does not appear, then see next option OPTION 2 - Some filter may use color controls instead or additionally to the open image and so they are in the settings tab, and you need to load your own images there, and you can put an image for each color control that is available HOW TO USE COLOR CONTROLS Guide to show how to use color controls Be aware that now there is no drop down menus IF YOU ARE USING FF AS A PLUGIN If you are using FF as a plugin of a host then the image you load from the host software is always through option 1 and you need to do it manually if the filter use color controls |
| Posted: July 16, 2020 9:43 am | ||||||
Ann B
Posts: 6 |
Thank you for helping me Space Ray. I will outline for you the process and the filters I used:
I was using FF9 as a plug in with PS6. I sent an image of a rose fr om PS to FF I went to effects tab in the folders list in FF and chose "frozen window" filter which was in Misc folder. I chose the first one on the bottom row of thumbnails (the spikey fish with lavender colours) In the preview pane wh ere my rose image was, there was the exact same image of the fish as was in the preset thumbnail, and my rose was no longer visible. I tried every version of the "frozen Window" preset and all seemed to replace my rose with the thumbnail image, whether it be the fish, the lifesaver. I will now investigate your last helpful instructions and see if it makes a difference, thank you. |
| Posted: July 16, 2020 8:22 pm | ||||||
Ann B
Posts: 6 |
After reading and re-reading your text.I have had a deeper look at this 'frozen window' filter and discovered in the settings that there is a box called 'stencil' and in there I was able to access the drop down menu and change the stencil image from the lifesaver to my rose.
I now have a filter that is working with my rose image instead of the preloaded stencils. PROBLEM SOLVED for now. Thank you also for the link to the colour info which will be useful also. I have had this software since version 3 and I love it. Thank you so much for your help. |
| Posted: July 16, 2020 9:41 pm | ||||||
Ann B
Posts: 6 |
When I say I have had this soft ware since version 3, I have never ventured beyond what the thumbnails provided and was constantly annoyed about the issue we have been talking about above. I upgraded to version 9 from version 4 and have decided to learn more about the possibilities it has, hence my reference to being a newbie.
| Posted: July 17, 2020 5:24 am | ||||||
27 unregistered users.
