I have seen that there may be someones that are new or does not know yet how to upload images to forum
PREPARE THE IMAGE TO BE UPLOADED
First before uploading the image, you need to know if is compatible with the forum, I mean that FF forum does not allow to upload files that are higher of 1000 Kb and that as far as I know is only allowed the jpg and png extensions
There seems to be no limit in the pixels size of the image if it is under 1000 Kb.
I have tried just now and I have uploaded a 1980 x 1280 jpg that has 260kb and it works and is showing right
So then the most important is the size of the file and not the pixels size, so if you are trying to upload a PNG it usually has a much higher file size than JPG, so then is much more recommended to use jpg
NOW UPLOAD THE IMAGE TO THE FORUM
There are two ways to do it
1 - Click on the "Choose File" button below the text box and sel ect the image you want and have already prepared
2 - Drag and drop the image fr om where it is to the "Choose File” button and it will copied here
and then when you click on the button to post it, is uploaded tha image and shown in the post as a thumbnail.
if it is over the allowed size it will show a red message to tell what is the maximun allowed size
Don't you wish this number were a bit larger? I'd be posting my work here more often but I don't because of this limitation.
westdale
Filters: 7
I have uploaded images in the past OK. Today, after a long time not doing so, I find I cannot load an image - not an error message, just nothing happens.
I browse to a jpeg on my desktop (PC) and the name appears under the text box - the preview only shows the text and not a thumbnail.
The image is 240Kb and 500x500.
Any help would be appreciated - it is probaby just that I am old and forgetful !
[and yes I tried to attach untitled.jpg to this message!]
I do not think that it may be your fault at all, and is not that you do not know, because from the information given you are doing it right, there may be something wrong in the server, and you may trying again later
I have to say that the first time I tried myself to upload the below image it happened the same as you have described and nothing happened, but then after trying again, it did work, so I suggest and recommend that you try again
westdale
Filters: 7
thanks
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
20 unregistered users.
