One thing I like much to see is to be able to use typographic letters or numnbers to convert a photo into a typographic creation and there are some good examples made here in Filter forge with some filters
Although regrettably there is no direct support for fonts you still can use any kind of font if you convert it into a graphic image with transparent background or use of the font filters by Threedee
_________________________________________________________________________
USING EXTERNAL FONTS INSIDE FF FILTERS
There are two ways,
1 - the easiest and faster is to use already converted letters that are in PNG or PSD format so you can load them directly in FF
2 - Convert any font you may want to use to PNG format
You can use PSD Fonts Letters inside your filters NOW ! without FF 4.0
I have made different filters using the fonts made by ThreeDee and also have made one that will let you use any external font that you may want to use inside FF, although you have to prepare the fonts you want to use as images
Alphabet ANY FONT Texture Creator Basic Seamless by SpaceRay
And follow this guide thread to know how to use it with external fonts instead of the already built in
Be able to use ANY FONT with Alphabet Texture Creator Extended filter
FONTS BUILT INSIDE FILTER FORGE TO BE USED
But also in FF there are some already fonts created thanks to some clever, genius, awesome and hard worker like ThreeDee have made it possible as shown here
TD Europa Sans Caps Proc Font Advanced by ThreeDee
Arial TD font by ThreeDee
Arial TD numbers by ThreeDee
TYPOGRAPHIC FILTERS ALREADY AVAILABLE
And here are filters that are already built to use with your images
The Numbers Game by CFandM that was done beautifully and awesome inspired by thread shown here from a movie posters
Alphabet Photos by SpaceRay
MORE FILTERS
And there are more in search for FONT in the filter library
Or this search for ALPHABET in the filter library
ALIEN WRITINGS AND WEIRD LETTERS
There are also available some alien writings and cool symbols availble
GLYPH search in the filter library with many results
Or also this
ALIEN WRITING search in filter library
OUTSIDE OF FILTER FORGE
Here are some examples made for Photoshop Typographic artistic compositions using Photoshop actions
26 unregistered users.
