siSINka
Is it even possible?
For example, if it's possible to generate a rectangular map if I use this filter:
https://www.filterforge.com/filters/15211.html
Thanks
The filter uses "square" components (Profile Gradient & Polygon for example). Also the XY Anchors need to be changed to Image Bounds. It is possible to create a rectangular map, but would require some work. Ask the author. I messed around with the filter a bit and could see a way to alter it, but it would take too much time and I don't want to mess with the authors work.
siSINka
Thanks for the explanation!
This map was just an example, it was nothing specific. I still have a lot to study…
28 unregistered users.
