gerdich
Posts: 2 |
I would like to use FilterForge to create procedural content in unity at runtime (terrain, worlds, textures, art pictures). It would be very cool if there was a redistributable Runtime for iOS, Android, Windows and OSX.
The best would be if there was a redistributable runtime in C# |
| Posted: May 19, 2019 4:05 pm | ||
Posts: 3507 |
Sorry, no hope for a redistributable runtime of any kind. However we consider adding support for Unity shaders, so in some future FF version you will be able to generate Unity-ready maps. No ETA and no promises though.
| Posted: May 20, 2019 5:41 am | ||
Using Filter Forge output maps is not very difficult to be used in Unity because Unity is able to import textures maps when making a material
Here is a possible way to do it Use Filter Forge with Unity Although I think that there are easier ways to do it and more simple. Also you can use Filter forge texture maps to create a Substance material and so it is directly compatible with Unity Also you can use alternatively the Bitmap2Material software Bitmap2Material 3 for Unity 5 |
| Posted: May 20, 2019 6:11 am | ||
17 unregistered users.
