magiclight
MagicLight
Hi!
In the xml file for the command line renderer I should specify the preset to use (zero based index) and this works fine but I cannot get it to work with my own custom saved presets for some reason, I have 20 predefined presets (0-19) and they work fine but when I enter 20 to use the first custom preset it does render but it is using the last predefined preset I think (19) not my custom preset (20), do I need to specify custom presets for a filter in some specoial way ?
Hi and welcome to the forums!
Please make a copy of the filter in the My Filters folder, then make a null edit (open the filter in Filter Editor, make any change, undo and save), then you're good to go with the command-line renderer.
18 unregistered users.
