Yarns The Cat
Yarns The Cat
Hi Y'all,
I just decided to do a test install of FF8 on my PopOS (System76) Ubuntu laptop. I'm new to Filter Forge, and haven't really used Wine a whole lot. But, I figured I'd give it a try with the sale.
I followed a few links here and Google searches elsewhere to get it to install and run with links from Chrome. And, so far, it looks like it performs decently.
So, here are the steps:
1) I installed wine-2.0.2 from my OS installer and set it up for Windows 10,
2) I downloaded FF from the DL page,
3) Then, I went into my Downloads folder and typed:
Code
   wine Filter\ Forge\ 8\ Setup.exe
4) After that, I setup a bash script launcher, and saved it as /usr/bin/filterforge, with:
Code
#!/bin/sh
export WINEPREFIX=/home/$(whoami)/.wine
wine ~/.wine/drive_c/Program\ Files/Filter\ Forge\ 8/Bin/Filter\ Forge\ x64.exe $@
(If you're on a 32-bit system, you'll need to add export WINEARCH=win32 to your script.)
5) I'm using Gnome Desktop, so I added the lauchers for it. In ~/.local/share/applications I created filterforge.desktop and added:
Code
[Desktop Entry]
Name=Filter Forge
Exec=/usr/bin/filterforge %u
Type=Application
Terminal=false
MimeType=x-scheme-handler/filterforge
6) Then, in the same directory, I updated mimeapps.list and added the following line to the bottom:
Code
x-scheme-handler/filterforge=filterforge.desktop
7) Then, finally, when I clicked on a filterforge:// link on the Filter Forge website, Chrome asked if I always wanted to use the mime application, and I said yes.
The only issue I keep getting now is a warning that says, "Error accessing the Category at 'My Filters'." And, it did crash once. But, hopefully, if there are others doing this, we can all work together and iron these out.
Good job on getting this far!
I would like to try this but only if I first figure out how to use the wireless card with Ubuntu, otherwise I won't even bother booting it up.
ghost
Mr
Woohoo!
mac6
Great job! Thank you. This means you can also run the Windows version of FF on Mac OS X. Have you added FF to wine compatibility database?
Tsu Dho Nimh
Bottom-Feeding Filter Scavenger
WOW ... shiny new Mint 19 install and you hand me this! Thank you.
Must try (and must upgrade FF)
Tsu Dho Nimh
GRRRR ...
FilterForge 9 installs under WINE but after that it opens with
And that's as far as it gets.
PROGRESS:
Installing with the WINE 4.0 installer creates most of what you need.
I created the file mimeapps.list with this line (whether you have mimeapps.list or not will depend on what you have already installed).
That gets it to open, and the filters in the trial software work as they should, but if I try to open a filter from filterforge.com nothing happens. That is a browser issue, not a FilterForge issue.
The workaround of using the "obsolete" built in library browser works ... so I'm HAPPY!!!!!
MORE PROGRESS:
I have no clue what changed in my browser, but Firefox now opens Filter Forge if I click the button on the filter's web page.
25 unregistered users.
