Anita
Anita
Hi ....How do you use more than one filter on a photo... because it changes it to the following filter you use without blending them together..even if you save it first it will change it to the next filter you use..How do you Blend them ? ♥
emme
If you want to apply filter2 to the result of filter1, you would apply filter1 - save - load the saved image - apply filter2.
Filters vary in the way they blend things together, so if you want something specific, you can try modifying the filters, or use an external image editor to blend the results together.
Anita
Anita
Thank you for your reply emme ♥
Or you can apply filter1, press Ctrl+C - Ctrl+V (copy and paste), then apply filter2.
Anita
Anita
Thank you for your replies..very helpful thanks ♥
Grimbly
Grimbly
You could also copy Filter 2 from the editor and paste it into Filter 1 then make the necessary connections to combine the two of them and save it as a new filter. Then just run the one filter on the image/images smile:)
