Katanya
The Lonely Tigress of Shannara
I have tried copying the contents of the Filter Forge Plugin folder to the Photoshop plugin folder, but the filter isn't adding. This is a new version of Photoshop for me, so not sure what else I might need to tweak to get it working.
Can anyone help me out?
Generally you shouldn't copy any files manually but use the built-in installer.
What Filter Forge version are you using?
Katanya
I am using 7. The installer did not give the option of adding a Photoshop plugin, just the standalone version.
FF7 should support CC 2018. Do you have a localized (non-English) version?
Please run CC 2018, select Help > System Info and post its output here.
Katanya
Adobe Photoshop Version: 20.0.0 20180920.r.24 2018/09/20: 1193433 x64
Number of Launches: 13
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.17134.1
System architecture: Intel CPU Family:6, Model:14, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 6
Logical processor count: 12
Processor speed: 3 MHz
Built-in memory: 32690 MB
Free memory: 20955 MB
Memory available to Photoshop: 29936 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=8192
glgpu[0].GLName="NVIDIA GeForce GTX 1080"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="25.21.14.1681"
glgpu[0].GLRectTextureSize=32768
glgpu[0].GLRenderer="GeForce GTX 1080/PCIe/SSE2"
glgpu[0].GLRendererID=7136
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_8a9bc5eec38312d8\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_8a9bc5eec38312d8\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_8a9bc5eec38312d8\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nvami.inf_amd64_8a9bc5eec38312d8\nvldumdx.dll"
glgpu[0].GLDriverDate="20181102000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.2 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=8192
clgpu[0].CLName="GeForce GTX 1080"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="416.81"
clgpu[0].CLBandwidth=2.31642e+11
clgpu[0].CLCompute=3209.78
License Type: Subscription
Serial number: 96040775959284351414
GUIDBucket:Composite Core (enable_composite_core): onComposite Core UI (comp_core_ui): offDocument Graph (enable_doc_graph): off
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\
Temporary file path: C:\Users\User\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 465.2G, 375.3G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2019\Plug-Ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2018/08/14-01:11:25 79.600623 79.600623
AdbePM.dll PatchMatch 2018/09/10:19:04:15 1.601805 1.601805
AdobeLinguistic.dll Adobe Linguisitc Library 13.0.0.0
AdobeOwl.dll Adobe Owl 5.3.0
AdobePDFL.dll PDFL 2018/08/23-00:56:13 79.301181 79.301181
AdobePIP.dll Adobe Product Improvement Program 8.0.0.41.47939
AdobeSVGAGM.dll AdobeSVGAGM 79.600623 79.600623
AdobeXMP.dll Adobe XMP Core 2018/08/13-16:40:22 79.163499 79.163499
AdobeXMPFiles.dll Adobe XMP Files 2018/08/13-16:40:22 79.163499 79.163499
AdobeXMPScript.dll Adobe XMP Script 2018/08/13-16:40:22 79.163499 79.163499
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2018/08/14-01:11:25 79.600623 79.600623
ahclient.dll AdobeHelp Dynamic Link Library 4.0.0.0
AIDE.dll AIDE 2018/08/10-16:31:38 79.600470 79.600470
ARE.dll ARE 2018/08/14-01:11:25 79.600623 79.600623
AXE8SharedExpat.dll AXE8SharedExpat 2018/06/25-18:00:38 79.598424 79.598424
AXEDOMCore.dll AXEDOMCore 2018/06/25-18:00:38 79.598424 79.598424
Bib.dll BIB 2018/08/14-01:11:25 79.600623 79.600623
BIBUtils.dll BIBUtils 2018/08/14-01:11:25 79.600623 79.600623
boost_date_time.dll photoshopdva 12.1.0
boost_filesystem.dll photoshopdva 12.1.0
boost_system.dll photoshopdva 12.1.0
boost_threads.dll photoshopdva 12.1.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2018/08/14-01:11:25 79.600623 79.600623
CRClient.dll Adobe Crash Reporter Client DLL 2.0.3.0
dnssd.dll Bonjour 3,0,0,2
dvaaccelerate.dll photoshopdva 12.1.0
dvaappsupport.dll photoshopdva 12.1.0
dvaaudiodevice.dll photoshopdva 12.1.0
dvacore.dll photoshopdva 12.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 12.1.0
dvamediatypes.dll photoshopdva 12.1.0
dvametadata.dll photoshopdva 12.1.0
dvametadataapi.dll photoshopdva 12.1.0
dvametadataui.dll photoshopdva 12.1.0
dvaplayer.dll photoshopdva 12.1.0
dvascripting.dll photoshopdva 12.1.0
dvatransport.dll photoshopdva 12.1.0
dvaui.dll photoshopdva 12.1.0
dvaunittesting.dll photoshopdva 12.1.0
dynamiclink.dll photoshopdva 12.1.0
ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1157194 81.1157194
icucnv58.dll International Components for Unicode 58, 2, 0, 0
icudt58.dll International Components for Unicode 58, 2, 0, 0
icuuc58.dll International Components for Unicode 58, 2, 0, 0
igestep30.dll IGES Reader 9.3.0.113
JP2KLib.dll JP2KLib 2018/06/25-18:00:38 79.271024 79.271024
libifcoremd.dll Intel® Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel® OpenMP* Runtime Library 5.0
libmmd.dll Intel® C/C++/Fortran Compiler 18.0.0
LogSession.dll LogSession 8.0.0.41.47939
mediacoreif.dll photoshopdva 12.1.0
MPS.dll MPS 2018/08/06-15:20:35 79.600183 79.600183
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2019 20.0
Plugin.dll Adobe Photoshop CC 2019 20.0
PlugPlugExternalObject.dll Adobe® CEP PlugPlugExternalObject Standard Dll (64 bit) 9.2.1
PlugPlugOwl.dll Adobe® CSXS PlugPlugOwl Standard Dll (64 bit) 9.2.1.39
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2019 20.0
SCCore.dll ScCore 2017/08/31-12:13:14 81.1157194 81.1157194
SVGRE.dll SVGRE 79.600623 79.600623
svml_dispmd.dll Intel® C/C++/Fortran Compiler 18.0.0
tbb.dll Intel® Threading Building Blocks for Windows 2018, 0, 2017, 1205
tbbmalloc.dll Intel® Threading Building Blocks for Windows 2018, 0, 2017, 1205
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WinRTSupport.dll Adobe Photoshop Windows RT Support 20.0.0.0
WRServices.dll WRServices Tue August 14 2018 12:26:24 Build 0.23627 0.23627
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Accented Edges 20.0 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 20.0 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 20.0 - from the file “Filter Gallery.8bf”
Average 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Average.8bf”
Bas Relief 20.0 - from the file “Filter Gallery.8bf”
BMP 20.0 - from the file “Standard MultiPlugin.8bf”
Camera Raw 11.0 - from the file “Camera Raw.8bi”
Camera Raw Filter 11.0 - from the file “Camera Raw.8bi”
Chalk && Charcoal 20.0 - from the file “Filter Gallery.8bf”
Chrome 20.0 - from the file “Filter Gallery.8bf”
Cineon 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Cineon.8bi”
Clouds 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Clouds.8bf”
Collada 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Color Halftone 20.0 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 20.0 - from the file “Filter Gallery.8bf”
Conté Crayon 20.0 - from the file “Filter Gallery.8bf”
Craquelure 20.0 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 20.0 - from the file “Standard MultiPlugin.8bf”
Crosshatch 20.0 - from the file “Filter Gallery.8bf”
Crystallize 20.0 - from the file “Standard MultiPlugin.8bf”
Cutout 20.0 - from the file “Filter Gallery.8bf”
Dark Strokes 20.0 - from the file “Filter Gallery.8bf”
De-Interlace 20.0 - from the file “Standard MultiPlugin.8bf”
Dicom 20.0 - from the file “Dicom.8bi”
Difference Clouds 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Clouds.8bf”
Diffuse Glow 20.0 - from the file “Filter Gallery.8bf”
Displace 20.0 - from the file “Standard MultiPlugin.8bf”
Dry Brush 20.0 - from the file “Filter Gallery.8bf”
Eazel Acquire 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “EazelAcquire.8ba”
Entropy 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Export Color Lookup Tables 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Export3DLUT.8be”
Extrude 20.0 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “FastCore.8bx”
Fibers 20.0 - from the file “Standard MultiPlugin.8bf”
Film Grain 20.0 - from the file “Filter Gallery.8bf”
Filter Gallery 20.0 - from the file “Filter Gallery.8bf”
Flash 3D 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Fresco 20.0 - from the file “Filter Gallery.8bf”
Glass 20.0 - from the file “Filter Gallery.8bf”
Glowing Edges 20.0 - from the file “Filter Gallery.8bf”
Google Earth 4 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Graphic Pen 20.0 - from the file “Filter Gallery.8bf”
Halftone Pattern 20.0 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 20.0 - from the file “HDRMergeUI.8bf”
HSB/HSL 20.0 - from the file “Standard MultiPlugin.8bf”
IFF Format 20.0 - from the file “Standard MultiPlugin.8bf”
IGES 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Ink Outlines 20.0 - from the file “Filter Gallery.8bf”
JPEG 2000 20.0 - from the file “JPEG2000.8bi”
Kurtosis 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Lens Blur 20.0 - from the file “Lens Blur.8bf”
Lens Correction 20.0 - from the file “Lens Correction.8bf”
Lens Flare 20.0 - from the file “Standard MultiPlugin.8bf”
Liquify 20.0 - from the file “Liquify.8bf”
Matlab Operation 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “ChannelPort.8bf”
Maximum 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Mean 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Measurement Core 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “MeasurementCore.8me”
Median 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Mezzotint 20.0 - from the file “Standard MultiPlugin.8bf”
Minimum 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
MMXCore Routines 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “MMXCore.8bx”
Mosaic Tiles 20.0 - from the file “Filter Gallery.8bf”
Multiprocessor Support 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “MultiProcessor Support.8bx”
Neon Glow 20.0 - from the file “Filter Gallery.8bf”
Note Paper 20.0 - from the file “Filter Gallery.8bf”
NTSC Colors 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “NTSC Colors.8bf”
Ocean Ripple 20.0 - from the file “Filter Gallery.8bf”
OpenEXR 20.0 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 20.0 - from the file “Filter Gallery.8bf”
Palette Knife 20.0 - from the file “Filter Gallery.8bf”
Patchwork 20.0 - from the file “Filter Gallery.8bf”
Paths to Illustrator 20.0 - from the file “Standard MultiPlugin.8bf”
PCX 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “PCX.8bi”
Photocopy 20.0 - from the file “Filter Gallery.8bf”
Picture Package Filter 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “ChannelPort.8bf”
Pinch 20.0 - from the file “Standard MultiPlugin.8bf”
Pixar 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Pixar.8bi”
Plaster 20.0 - from the file “Filter Gallery.8bf”
Plastic Wrap 20.0 - from the file “Filter Gallery.8bf”
PLY 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Pointillize 20.0 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 20.0 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “PBM.8bi”
Poster Edges 20.0 - from the file “Filter Gallery.8bf”
PRC 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Radial Blur 20.0 - from the file “Standard MultiPlugin.8bf”
Radiance 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Radiance.8bi”
Range 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Render Color Lookup Grid 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Export3DLUT.8be”
Reticulation 20.0 - from the file “Filter Gallery.8bf”
Ripple 20.0 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 20.0 - from the file “Filter Gallery.8bf”
Save for Web 20.0 - from the file “Save for Web.8be”
ScriptingSupport 20.0 - from the file “ScriptingSupport.8li”
Shake Reduction 20.0 - from the file “Shake Reduction.8bf”
Shear 20.0 - from the file “Standard MultiPlugin.8bf”
Skewness 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Smart Blur 20.0 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 20.0 - from the file “Filter Gallery.8bf”
Solarize 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “Solarize.8bf”
Spaces 20.0 - from the file “Spaces.8li”
Spatter 20.0 - from the file “Filter Gallery.8bf”
Spherize 20.0 - from the file “Standard MultiPlugin.8bf”
Sponge 20.0 - from the file “Filter Gallery.8bf”
Sprayed Strokes 20.0 - from the file “Filter Gallery.8bf”
Stained Glass 20.0 - from the file “Filter Gallery.8bf”
Stamp 20.0 - from the file “Filter Gallery.8bf”
Standard Deviation 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
STL 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Sumi-e 20.0 - from the file “Filter Gallery.8bf”
Summation 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Targa 20.0 - from the file “Standard MultiPlugin.8bf”
Texturizer 20.0 - from the file “Filter Gallery.8bf”
Tiles 20.0 - from the file “Standard MultiPlugin.8bf”
Torn Edges 20.0 - from the file “Filter Gallery.8bf”
Twirl 20.0 - from the file “Standard MultiPlugin.8bf”
U3D 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Underpainting 20.0 - from the file “Filter Gallery.8bf”
Vanishing Point 20.0 - from the file “VanishingPoint.8bf”
Variance 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
Water Paper 20.0 - from the file “Filter Gallery.8bf”
Watercolor 20.0 - from the file “Filter Gallery.8bf”
Wave 20.0 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “U3D.8bi”
WIA Support 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “WIASupport.8li”
Wind 20.0 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 20.0 (20180920.r.24 2018/09/20: 1193433) - from the file “WBMP.8bi”
ZigZag 20.0 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins:
Filter Forge 7 7.007.46686.60178 Release, February 13, 2018 11:09 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Plug-Ins\x64\Filter Forge 7 x64.8bf”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load:
Filter Forge 7 NO VERSION - - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Plug-Ins\Filter Forge 7.8bf”
Extensions:
com.adobe.Butler.backend 2.1.1 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
com.adobe.inapp.purchase 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_0_231\purchaseStock.html”
com.adobe.stock.panel.licensing 0.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.stock.panel.licensing\index.html”
Libraries 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_0_231\index.html”
New Document 2.5.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.5.1\fnft.html?v=2.5.1.8”
com.adobe.inapp.typekit.purchase 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_3_0_231\purchaseTypekit.html”
Home 2.5.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.5.1\index.html?v=2.5.1.102”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 4.6.3 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2019\Required\CEP\extensions\com.adobe.photoshop.crema\index.html”
Installed TWAIN devices: NONE
Thank you. This line
indicates you have Photoshop CC 2019 and not 2018. Filter Forge 7 doesn't support CC 2019 but Filter Forge 8 does. If you install FF8 it should enable the plugin automatically.
Alternatively you can install Photoshop CC 2018 (that reports itself as Photoshop Version: 19.0) and use your existing FF7.
Katanya
Well, poop. I guess I didn't realize it had installed 2019. I'll download Filter Forge 8. Thank you.
earthbound
For me, the Filter Forge 7 plugins work if copied from the Plugin folder from Photoshop CC 2018 x64 to Photoshop 2019 x64.
You refer to the prophecy of the pastry that will bring balance to the Force. And you believe it's this...donut?
Fred_Weiss
Digital Art Developer-Publisher
That worked for me also.
Fred Weiss
Allied Computer Graphics, Inc.
earthbound
Filter Forge: in my opinion you should release minor updates for older versions of Filter Forge which do any/all the following:
- check for and install to the Plugin folder for newer versions of Photoshop Creative Cloud
- (more flexible) allow install to an arbitrary location which programs that use photoshop-compatible plugins can be pointed to
- back up the extracted plugin somewhere for users to manually copy into wherever Adobe moves the newest \Plugin folder next (I don't like that their design moves it around annually)
- clearly document all this somewhere
It's lame that I needed to install Photoshop 2018 creative cloud, run the Filter Forge 7 installer, install the plugin to the ~2018 \Plugins folder, navigate to that folder, copy the FF plugin, navigate to the 2019 \Plugins folder, paste it there, and launch ~2019 and test it to discover it works. I paid for FF 7 and in only a few years its effectively dead to me as far as using it from within Photoshop is concerned unless I do all this extra troubleshooting legwork (and back up the extracted plugin to an archive in preparation to do this if/when there's another Photoshop CC release in yet another new folder).
The bare minimum you could do is test that FF plugins from a few years ago (1 to 2 years?) work in new Photoshop versions and document for users that it does and how to get it to.
17 unregistered users.
