grue
hello. i own FF6.0 and it tells me there's an update for 6.010. i also get messages when using FF6.0 stand alone or within photoshop that tells me i have to update to 6.010 to use the feature - which is pretty much a lot of things i try to do.
problem i'm seeing is that the Tools>Updates doesn't work for me. I get an error pop-up window that gives a long URL and then the HTTP status code: 407.
i've tried going to the FF download tab on this site, but only see FF7.0 i can't find FF6.010 to download.
i'm not sure if my license allows me to download 7.0? what might i do next?
thanks!
Thanks for your report, we'll look into the auto-updater behavior. For now please download 6.010 manually using this link:
For Windows:
https://filterforge.com/download/Filte...0Setup.exe
or for MacOS:
https://filterforge.com/download/Filte...0Setup.dmg
grue
thanks! i've attached the screen shot of the error if this helps. downloaded the upd ate so i should be all se t!
grue
all of that and i just decided to upgrade to version 7. ha. oh well.
HTTP error 407 means the inability to use a proxy. Do you use proxied access to the Internet? If no, please run FF and select Tools > Options > Online > Direct connection.
