javalang
Hi Forum,
I'm new to FF6-PRO and I'm wondering about the "Search Filters" function in the "Filter Library" dialog. I use Windows-10 and each time I press the Find-button I end up in an endless-loop with "Searching...", even after several minutes there is no result. I used search terms of existing filters, with or without wildcards, no success.
Is it a bug, a configuration problem or something else?
Thanks in advance
I suppose you're using the Obsolete library browser? It's a known issue. Please note the word "obsolete": the search is unlikely to be fixed soon.
javalang
yes I'm using the "obsolete" library browser, thx for the info. So it's very unconvenient to step trough the filters by category, one by one.
On the other hand, searching via external browser I only can download one filter at a time and I'm running into an issue "FF is already running" if FF is already open (which means closing FF first before downloading).
I cannot imagine that this is a designed workflow, I'm very unhappy with this smile:( .
