Whats Gnu.
I'm sure this is an extremely simple question for most people here, but I haven't yet found the answer: When I render-out an image with a FF effect, the background sample image comes along with it when saved as a .tiff or .png, for instance. I try "use transparency", but I still get the sample lifesaver or kingfisher bird or daisy with ladybug, etc. in the background (on the same layer) when I bring it into Photoshop.
Can somebody please tell me how to lose the sample image when saving?
Thanks much in advance! smile:)
Mardar
Graphics Junkie
Filters: 61
HI Whats Gnu.
Using the "transparency" only makes the background behind the image transparent. Example the life saver or kingfisher and so on.
Instead do this. Go up to file then click on New image and a dialog box will open. Set it to the size of your image then click on the color box and the color picker will open up. The last setting at the bottom of the color picker dialog box (It has a A beside it) move the slider all the way to the left and this makes the color invisible. click ok and you will have a transparent image. If this doesn't help I'll add some screen shots
Whats Gnu.
BINGO! ~ ~ There's the ticket! That works just right!
Thank you, Mardar. You made my day! smile:D
Mardar
Graphics Junkie
Filters: 61
Great! So glad to help. smile;)
