Here I want to put this thread for all the expert, skilled and experienced filter forgers that know how to use all the new greenified components from FF 6 and FF 7 beta 2
So here you can show your creations like a gallery
Also can help with some hints and tips, tutorials or examples on how to use these new greenified components and what things can be done now that was not possible before
What doors are opened now for more flexible creations?
Thanks for any possible help
Ok so in previous versions of FF you COULD do this but in this version all it takes is 1 checker component that gets modulated.
Note: this is using the Bomber Plus and checker components.
Example filter.
CheckerBomber.ffxml
You can rotate a profile gradient without having int controls. Now you can modulate it with any value input in other words you can control it with grayscale values.
Try changing the kaleidoscope patterns and see what you can get.
Rotate Example.ffxml
You can now have all 4 wave curves drawn in a single component without having to create 4 separate wave curve components and 4 gradients.
Thanks very much for the examples, will see how they work
I think that FF team should give more examples and explanations on how these new components can be used that before was not possible or as you have said, that now is easier and more simple to make
Would be good to have more examples and ideas
Any possible help will be greatly welcomed and appreciated
Please, does anyone else have more possible examples and tips on how to use creatively these new greenified components?
Some of them may be simple and easy to guess, test and experiment, but others not
It would be good that the anyone from FF team could show cool and great ways to use these new greenified components as promotion for motivation to upgrade to FF 7
Uhhh have you checked the stuff I made at least? Do you understand what was going on in the examples? If not let me know, I'll go through them piece by piece.
I feel like you can beg for more examples but without foundational understanding of what the greenified stuff does, it's really no use getting even more examples.
