kbryan
When installing a new or Beta version of Filter Forge, should the old version be uninstalled? Does it overwrite/upgrade older versions or is a new separate version installed? What is the best practice? Thank you.
kbryan
it is really a totally new software that is independent from any other version, it will not overwrite the old version, this only happens with he same version number
The licenses and software are each one separate for each version, and can be installed together
I have FF 4.0, FF 5.0 and FF 6.0 in the same computer and same hard drive without problem, they do not share the filters or any other files
So if you want to install another version with different number, you do not have to uninstall any other older version
kbryan
Thank you for your help! smile:)
kbryan
Bookwormious
But what would happen, if I do uninstall FF 4 and FF 5, when I get FF 7?
I keep buying the next update and at present have FF 4, FF 5 and FF 6 on my laptop. But I also have quite a lot of other stuff (and really many FF filters) on my machine, so am afraid of running out of space. Will removing the oldest version of FilterForge effect the newest and perhaps even prevent it from working?
As far as I know from my personal experience there is no problem removing any older version of FIlter Forge, because they have individual and separate files, filters, presets, etc. so there is no connection between any version with another version, either newer or older
I have also FF 4, FF 5, FF 6 and FF 7 beta and there is no problem between them.
Bookwormious
Thank you ever so much for answering me smile:)
