n8crow
I'd like to right click on an image in fsviewer and launch filter forge with that image as a parameter. Fsviewer passes the full path and file name to the external exe but filter forge is ignoring the parameter and opening with its default source image.
Are there other flags I need to pass in addition to the file to allow filter forge to recognize this parameter?
Thanks.
Attached is an image of the configuration for launching Photoshop and Filter Forge. Photoshop works fine...
Please take a look at the command-line FF version:
https://filterforge.com/more/help/Misc...derer.html
n8crow
Thanks. But I'm wanting to open the interactive version, where I can try various filters. Basically just open Filter Forge to a file rather that hunt for it through the open menu. This is not an exotic feature request, most native windows applications: browsers, editors, graphics, etc. allow a filename parameter to be passed to the executable so things like "Open With" from Windows Explorer work. It's curious that Filter Forge does not have this capability (except in an isolated command line version which is not the same use case at all.)
