paulcopeland
Paul from Australia
G'day from Australia.
I am a beginner and need help.
I now have Filter Forge 6 for Windows.
I have a small snippet open in the editor, which shows a Rotate Component.
When I look for the Rotate Component in the Components, I can't find it. I assume that I have completely lost the plot.
Could someone please enlighten me.
Many thanks.
Paul.
Winner Jean Bogan Piano Composition Competition 2016
You can find that under the "Transform" category....
Paul, please check our manual: sections for each component tell you where you can find that component.
I had the same problem at the beginning that was not able to find the components I wanted, but then I knew that there is the available search using the first letter of the component
1 - Go to components list
2 - Select All category (the first one)
3 - Go to to the first component of the list and select it
4 - Press the first letter of the component that you want to search
5 - For example in this case it would be the R key for Rotate
6 - If the first result that is shown is not the rotate component, just keep pushing R key (without keeping it pressed) until the rotate component appears
I know that is not the fastest or best way to find components but is an alternative way
For more information and added details see this thread about this same topic
component search
paulcopeland
Paul from Australia
Thank you everyone for your responses.
I spent probably half an hour looking at all the Components.
The problem was that I was looking for a Component that was visually the same as the image that I uploaded.
Thank you again, and best wishes to you all in your projects.
Seeya.
34 unregistered users.
