Patricia Gardner
Posts: 2 |
Hi y'all! I came across a filter while downloading filters to my FF, but I can't find it now. It combines two other filters... it's not Double Exposure.
I never tried, because I had to use two other filters, and I was in process of downloading. Can anyone help me with this? I don't know if I downloaded it or not, don't remember the name or anything, only that what it did intrigued me. Thank you! Patricia |
| Posted: August 10, 2016 11:54 am | ||
Do you mean combining two filters, or combining two images?
Double Exposure by Kochubey combines two images. If you're looking for something similar, try searching "collage" or "deep dream"... any of these? http://filterforge.com/filters/9982.html http://filterforge.com/filters/10332.html http://filterforge.com/filters/12630.html http://filterforge.com/filters/13527.html http://filterforge.com/filters/13825.html |
| Posted: August 11, 2016 7:32 pm | ||
Patricia Gardner
Posts: 2 |
@Indigo Ray, it combines two filters, not images. Thanks!
| Posted: August 16, 2016 3:03 pm | ||
Do you remember what the effects were aside from combining two filters..
Could be easier to pinpoint with a little more detail...Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: August 17, 2016 10:32 am | ||
| raabix |
I have never seen a way to combine two filters other, than doing that manually. So you open one filter (hopefully it's just a simple filter, not one with bump and specular channels), then you copy the network, open the other filter, paste it and use a blend node with the desired blending method to combine those.
I was sometimes thinking that this would be a useful feature, but imagine combining two really slow (computation intensive) filters... The result would be a superslow, so I guess that there are good reasons why this is not a feature of FF. |
| Posted: October 10, 2016 2:41 pm | ||
PayPaul
Posts: 106 |
Isn't there a script or some kind of plugin mentioned in the filter Forge wiki?
The links on the Wiki for external plugins and scripts for FF are dead except for this one, which seems to use the command line. https://sourceforge.net/projects/filte...chwrapper/ Don't step on a dead dogma. It'll turn up again and bite you! |
| Posted: October 11, 2016 10:49 pm | ||
