ok, i know what a bit map is and i know what a bump map is, but what is 'specular' in 'specular strength' and 'specular exponent'? what's specular mean?
craig
Sethren
Specularity is just another term for Highlights which ofcourse are caused by reflective and refractive surfaces as light sources bounce off of any given surface which can be attributed to liquids, metals and alloys, glass, plastics etc. I think specular exponent is how far outward the highlights spread? don't quote me on that...... Hope that helps! smile:D
Yes -- specular strength (or Reflectivity in the Editor) is how strong the reflection is, and specular exponent defines the sharpness of the reflection (called Reflection Blur in the Editor).
The only correction to Sethren's explanation is that we don't use the term "Highlight" in Filter Forge. While the term itself is perfectly valid and well accepted among CG people, we prefer to use the term "Reflection" -- since Filter Forge uses HDRI environments for lighting, and the term Highlight is mostly used for point lights.
We didn't want to use terms like that in the Editor to make it more accessible to people unfamiliar with insider terms like Specular Exponent. The rendered maps, however, are still called by their "industry names" - Bump Map (Height in the Editor), Diffuse Map (Surface Color in the Editor) etc -- because only the pros are going to render those maps.
Well, I just did smile:D
Sethren
Heh,heh... still learning terminology...... smile:)
thanks guys.
yup, terminology can kill you...or at least put you to sleep smile:)
craig
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
21 unregistered users.
