Ozmandias
I've had to replace my computer and want to install FF. I purchased version 3 some time ago. Several updates to v3 have been released since my original purchase. Will my key work on the latest version (3.016, I believe)or will I have to install the first version and each subsequent update?
Second question... old computer was 32-bit with WinXP. New computer is 64-bit with Win 8.1. I'm running 64-bit CS6. Will FF3 work as a plugin in my 64-bit CS6?
Thanks
-Oz
There are no "subsequent updates": you need to install the latest version (3.016 in your case) and register with your license info.
As for the second question, I don't remember the system requirements from FF3. You can check the help file for the list of supported host apps.
Ki_Ryn
(I found the answer to my question, but don't see a DELETE option for this comment)
15 unregistered users.
