stevedipaola
I am a university researcher/prof using FF in a chain of tools with my grad students. I own a few copies of FF4 for different computers. I have a new student that I need to give a new copy too. So with FF5 out, I thought I buy new FF5 for my computer (current w FF4) and move my current FF4 license off my computer and give that to the new student for their computer. I am in the midst of important work with many scripts on my computer so just want to make sure I do this correctly. Can I just use the newly bought FF5 license key to replace my current FF4 key and then give that FF4 key to my new students. Ort do I have to install ( and if so will that kill my scripts and library setups). Again I am trying not to lose my current routines and setup which at this point it pretty complex.
Suggestions for best way to handle this?
thanks in advance
I'm not sure I understand you correctly. FF4 and FF5 are separate programs, installing FF5 won't affect older installations.
From this phrase:
I assume you are ok with using FF4. If this is the case you should simply buy a new FF5 license to your student.
stevedipaola
I was not clear - I want to move up to FF5 on my computer (by buying a new FF5) and give my old FF4 license currently on my computer to my student, in a way where it is least disruptive to my computer's FF setup of scripts and filters.
Well, you can install FF5 on your computer, uninstall FF4 and then install FF4 on another machine. It's difficult to say whether it is disruptive for your scripts, just bear in mind that FF4 and FF5 are independent from each other.
stevedipaola
thanks
20 unregistered users.
