Bongo
I just upgraded from 4 to 5 and I moved My Filters and System folders and all is okay, but none of My Favorites are there, when I search for the filter by name it is not even in the other folders it's like they didn't even get moved with the rest of them, is there something else I need to move?
Thank you
Jerry
Edit: I just manually move some from 4 to 5 in the library folder and they still do not show when I search for them.
Moving Favorites is not officially supported but you can try to copy Favorites.xml:
FOR MAC:
from
/Users/Your_User_Name/Library/Application Support/Filter Forge 4/
to
/Users/Your_User_Name/Library/Application Support/Filter Forge 5/
FOR WINDOWS:
from
%APPDATA%\Filter Forge 4\
to
%APPDATA%\Filter Forge 5\
Bongo
Thanks GMM
I uninstalled it and then rebooted and installed 5 again and this time it asked me if I wanted to import my settings and filters and I did it imported 7 of my favorite I then just looked up the rest and install them so all is good now.
26 unregistered users.
