| chars |
Hi is there a plug in for using filter forge ingimp .
thanks |
| Posted: November 14, 2015 5:18 pm | ||
No, Gimp doesn't recognize the .8bf plugin file (I've tried). You have to export an image (and possibly a second image to use as a selection) from Gimp, import that image (and selection) in Filter Forge, save the rendered image, and import in Gimp. No shortcuts
| Posted: November 14, 2015 7:25 pm | ||
| chars |
ok thanks
| Posted: November 14, 2015 7:50 pm | ||
| ddaydreams |
Here's a list of some applications that FF will plug into
https://filterforge.com/download/hosts.html assuming you have Windows Some are inexpensive |
| Posted: November 14, 2015 10:48 pm | ||
| chars |
tanks
| Posted: November 14, 2015 10:50 pm | ||
Haras Arch
Posts: 226 |
I have had Serif Photo Plus in the past and get ads for newer versions pretty often -- has anyone had good results with pairing FF with it?
I wonder if it would work with PhotoFiltre Studio? That's the software I use a lot for working on images. I'm having a good time using FF as a standalone program, but I assume there must be benefits to using it in conjunction with another program. |
| Posted: November 15, 2015 11:59 pm | ||
25 unregistered users.
