Kev914
Is the librarain and the backup something that they mail mail to you?
When I upgraded to version 4, I added the librarian and the backup (or whatever it was called.) In the email I received, it said that Filter Forge would send me...not sure what... a download link?...within 2 days. But it has been more than two days.
In looking at the librarian, it looks like something they will send me on a disk. Is that correct?
Thanks
If you ordered an optional disc ($24.95 extra), then all your products will be burned on a disc and shipped to you. If you didn't order a disc, you should have received an email – please check your spam folder.
Kev914
I have a few question about the Librarian....
1. Does it only know about the files that were in the Librarian backup zip? (Not sure how it knew where the files were. They were in my Download folder, but it seemed to find them.)
2. If it doesn't know about new filters that get added to the website, how do I know which ones are new and which ones are already in the library?
3. Should I leave the librarian filters files where they are in the downloads folder? (That's just where I keep programs/files that I purchase.)
4. Once you send something from the Librarian to Filter Forge, does it stay there? Do you have to remove it? If they stay there, then over time, it would seem the library in Filter Forge would grow larger. (But I suppose you are unlikely to add everything.)
Thanks.
1. Librarian only deals with its own filter database which is incompatible with the ZIP archive. However filters inside Librarian and inside the ZIP file are the same (the difference is in the thumbnail format)
2. It's a filter backup, it doesn't mean to be updated. You can check the Recent filters page manually: https://filterforge.com/filters/
3. You can keep them, or delete them. You can always contact us to get your download link again.
4. Sorry, does it stay where? The filters you load from Librarian into Filter Forge will stay there as long as you use this Filter Forge version.
30 unregistered users.
