bettybop
bettybop
Is there a way to open an image in FF then render as a bump map etc. When I open an image and try , the filter menu is all greyed out except off and alpha map. I just need to make a bump map from my texture.
Filter Forge is more about creating new textures (that can have a bump map) rather than converting an existing image to bump. You can try using filters like these:
https://filterforge.com/filters/9954.html
https://filterforge.com/filters/7303.html
If they are not what you want you'd better create a new image from scratch in Filter Forge.
37 unregistered users.
