primitivedesign
I noticed a few things while running command line rendering that I hope someone can clear up for me. The first is that there are 2 separate processes in the Windows Task Manager (Windows 7, 64bit). Both have the same name:
FFXCmdRenderer-x86.exe *32
CPU 80-85% Memory 256MB+
CPU 0% Memory 576K
Is this normal? Should there be 2 processes like that?
Also, when I right-click on either of them, There is an option for "UAC Virtualization" which is already checked ON for both processes. What does that do, and should it be ON?
Yes, this is normal: Filter Forge launches two processes.
I'd recommend the following article for an overview of UAC virtualization.
