bilbaggins
bilbaggins
I can't locate the Colour Controls for the Builtin Preview Images...
the FilterForge blurb says:
You can also load the preview images into the new color controls (also introduced in Filter Forge 3.0) that allow loading images: click the triangle button next to the corresponding control in the filter controls area, select Built-In Preview Images and choose the image you need:
I must be in the wrong place but I can't find it... I am running Vers 3+
Any help appreciated!
KISS
Are you editing a filter or using a filter...If you are using a filter it depends on if the filters author included that function....If you are editing a filter it is in the slider category of components..
Mardar
Graphics Junkie
Filters: 61
Before you can use an image in the color control, you have to go into the editor and click on the color control you want to make image available in and click on "Allow image".
Save this and your color control will now have a menu bar to the right of it that you click and choose the image you want.
This is for editing your own filter as CFandM stated above. Not all filter by other authors have this function included.
bilbaggins
bilbaggins
MAny thanks mon amis!!! I had a suspicious it was an authors add on. You've hit the nail right on the head! Again merci beaucoup!
KISS
Mardar
Graphics Junkie
Filters: 61
You're very welcome. Glad we could help. smile;)
17 unregistered users.
