joBox
joBox
Filters: 4
1) I'm an artist ..... not a programmer.
2) I understand (mostly) the instructions for FFCmdRenderer found here: http://www.filterforge.com/more/help/Miscellaneous/CommandLineRenderer.html, BUT, I have no clue WTF this means when I try to run it: "Parse failed: not well-formed (invalid token) (file 'batch.xml', line 4, column 24)"
3) Funny this is, I'm COPYING straight fr om the example batch sample located here: Applications/Filter Forge 4/Resources/System/BatchSample.xml
4) So there error is somewhere within these lines:
<?xml version="1.0" encoding="utf-8"?>
<Tasks>
<Task>
<Image value="" width="300" height="400" />
<Selection value="" />
<Result path="~/Documents/Wood.bmp" />
<Filter value="~/Library/Application Support/Filter Forge 4/System/Library/Library_284-1.ffxml" />
<Preset value="0" />
</Task>
5) and THIS is why FFCmdRenderer BLOWS .... does the FF staff REALLY think this is easy, let alone efficient?
Can anyone explain what is wrong in line 4 ... and uh .... WHERE column 24 is smile:?:
Thanks,
joBox
The line 4 seems to be correct, and the entire batch sample renders correctly for us (provided that you've modified the paths accordingly). Please send the whole XML file you're rendering, and not an excerpt from it.
joBox
joBox
Filters: 4
Will reply shortly ...
joBox
joBox
Filters: 4
This is EXACTLY why there needs to be a GUI built around the FFCmdRenderer so we can BATCH RENDER ....
I've tried 2 ways .... 1) having the batch.xml within the folder where FFCmdRenderer is located, AND 2) having the FFCmdRenderer located on my desktop where the batch.xml is located. Neither work and both give me the same error.
Filter Forge command line renderer, version 4.010.
© 2006-2012 Filter Forge Inc. All rights reserved.
Professional Edition
Parse failed: not well-formed (invalid token) (file 'batch.xml', line 4, column 30)
joBox
joBox
Filters: 4
and this is the full xml file that was copied fr om the example file (just to make SURE I wasn't doing anything wrong):
<Tasks>
<Task>
<Image value="" width=“400" height="400" />
<Result path="~/Documents/Wood.p”g” />
</Task>
<GlobalSettings>
<RenderingOptions>
<UseMultithreading value="true" />
<Dither value=“false” />
<Progressive value="true" />
<OptimizeBlurs value="true" />
<AntiAliasBitmapComponentSources value="false" />
<Jitter value="0" />
<TemporaryFilesLocation value="" />
<RAMUsageLim it value=“90" />
<NormalMapFlipY value="false" />
</RenderingOptions>
<DefaultFormat value=“PNG” />
<BMP>
<BitDepth value="32" />
<FlipRowOrder value="false" />
<JPG>
<Quality value="98" />
<FullPrecision value="true" />
</JPG>
<TIF>
<FloatFormat value="false" />
<IncludeTransparency value="true" />
<ImageCompression value="LZW" />
</TIF>
<TGA>
</TGA>
<PNG>
<BitDepth value="16" />
<ImageCompression value="BEST" />
</PNG>
<EXR>
<ImageCompression value="PIZ" />
</EXR>
<PFM />
</GlobalSettings>
</Tasks>
joBox
joBox
Filters: 4
weird ... the gaps in there are because this HTML editor is reading </BMP> ad BOLD and </Bitmap> as BOLD ... or something like that, and the formatting is all screwed up now ...
Anyway ...
Any thoughts??
My System =
Mac Pro - 2 x 2.4ghz Quad-Core Intel Xeon
RAM = 28GB 1066MHz DDR3
OSX 10.9.3
thanks smile:)
joBox
That's why you'd better attach the xml file to the post rather than copying its contents. I can also see some garbled text in the Result path value.
26 unregistered users.
