using paint shop pro 10.
when loading FF from psp 10 it comes up fine, but i found one need to go back and check something in psp while FF was running. i couldnt do this. apparently FF wants to 'always be on top' and i couldnt even look at psp with FF open on the user side.
is there any way to do this?
craig
FF wants to 'always be on top' and i couldnt even look at psp with FF open on the user side. is there any way to do this?
Unfortunately, no -- FF like other plugins makes Photoshop/PSP its parent window. If you just wanted to see your original unmodified image, you can use the "Show Original" checkbox above the preview.
vladimir,
ok, thanks.
i didnt want to just see the original; i wanted to check the stats about the original image, size and resolution in particular.
craig
ok, by resizing the FF window and dragging it out of the way, i can now see my psp window.
craig
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
24 unregistered users.
