jesse lejeune
Posts: 1 |
Hello, I am trying to figure out how to import a image and just use the seamless tiling attribute. with out any other filter. i understand bump, spec, normal, and diffuse map. heading in that direction thanks
PS this is for standalone. thanks |
| Posted: April 8, 2014 12:23 am | ||
Posts: 3507 |
There are quite a few "seamlessizer" filters in the library, you can try and pick out the one that suits you.
| Posted: April 8, 2014 5:08 am | ||
| Velho |
Not possible. Seamless tiling applies only to the filter calculations, not external images.
You could try this filter: http://filterforge.com/filters/9908.html |
| Posted: April 8, 2014 5:17 am | ||
| TBH-1138 |
You could also try mine. Remember to keep seamless tiling on or else it'll just "remix" your texture.
| Posted: April 11, 2014 5:01 pm | ||
Totte
The best solution is to make a seamless texture by bombing out pieces of for example stones, grass etc, some day I will finish my filter that does that.
- I never expected the Spanish inquisition |
| Posted: April 14, 2014 5:26 pm | ||
15 unregistered users.
