i'm using paint shop pro 10 to test with.
when running filter forge as a plugin from psp 10, it loads fine. however, on the filter use side (not the filter create side), the bottom part of the window is hidden by my desktop taskbar. i can only see the top part of the 'Apply' and 'Cancel' buttons. i can move my taskbar down and hide it and then things are ok, but that's annoying.
Yes, probably it is set to "Auto-Hide". The only thing I can advise is hiding the taskbar, resizing the main window into a smaller size, then turning the taskbar on again.
ok, thanks.
craig
ok, that worked fine. i simply resized the window and that handled it. it also handles my other issue with not being able to see paint shop pro. i can now simply drag the FF window out of the way.
craig
33,867 Registered Users
+10 new in 30 days!
+210 new in year!
27 unregistered users.
