Sasserine
So I recently deleted my old photoshop off my computer, and installed the new CC version. How can I get my Filter Forge to show up in my plugins? Do I need to redownload it? And if I do will I have to know my license? Its been a while since I bought FF and I may not be able to find it. lol
Sasserine
OK so I copied the Filter Forge 3 files from C:/ProgramFiles (x86)/Filter Forge 3/Plugin/x64 to C:/Program Files/Adobe/Adobe Photoshop CC (64 Bit)/ Plug-ins
And it wouldn't even load. It just crashed. Soooo am I doing that wrong? Or do I need to get Filter Forge 4 to work with CC?
Instead of copying directly the plugin inside Photoshop, you could reinstall the latest filter forge 3.015 in exactly same folder as it is already, and then it will find the new photoshop and will install the plugin automatically for you.
Are you using the latest 3.015 version or is it another older one?
Another alternative is that the already installed FF 3.0 you have you can go to the menu Tools --> Updates... and see if there is a new version and install it
Please remove all files you copied manually and reinstall the latest update to Filter Forge 3 using this direct link:
http://www.filterforge.com/download/s...0Setup.exe
Sasserine
HI!! Me again, Got a new computer and am trying to download everything on it. I used the link above, but there was no option to install the plug-in for Photoshop, just the stand-alone. Any suggestions?
As far as I know IF you already have installed Photoshop CC and then after you install Filter Forge, it will automatically copy the Plug-in to the photoshop folder, so I think there is no need to ask FF to install it, although I really do not remember how is the installation of FF, so I am not sure.
Are you still using FF 3.0 or have upgraded to FF 4.0?
Because is you have FF 4.0 would be better to go the download page and use the download link from there.
Sasserine
Im still using FF3.0, I downloaded it and everything, but still no photoshop plugin. Maybe I just need to upgrade?
Sasserine, Filter Forge 3.0 supports Photoshop up to CC (not CC 2014). If you have a newer Photoshop version you can use Filter Forge as a standalone program or upgrade to version 4.
Sasserine
Okie dokie ty! ^_^
27 unregistered users.
