EAdams
I have FF3 Professional. If I buy the FF4 Basic edition (apparently there is no upgrade option from the Professional to the Basic edition), will I still be able to use FF3 on the same computer? Or will the FF4 installation overwrite the FF3 installation?
I never had the time or inclination to try to create a filter of my own and I probably never will have, which is why the Basic edition will suffice but you never know...
Thanks in advance for any help with this question!
YES! Any of the versions of Filter Forge are totally independent and you can all the versions if you would want in the same computer and they will be like different applications, also the same if you it as a plugin, will have each one it´s own plugin separate.
Any new update of filter forge will overwrite any of the previous version ONLY IF they have the same number, so FF 3.0.15 will be installed over 3.0.14, but 4.0.15 would never install over 4.0.14
Going from Professional to Basic edition is NOT an upgrade, is an downgrade of edition although is an upgrade of version
Well, you can ask to the customer support if they could allow you to have a downgrade from FF 3.0 Professional to FF 4.0 Basic.
Zep Palen
Filters: 10
EAdams. Remember that the Basic edition is not only limited to the Filter Editor.
It is also limited in which of the maps you can render. If you need to make bumpmaps, normalmaps etc. you will still need the Pro edition.
No, this is not allowed. However, as for today, Basic 4.0 is offered for only $44 — any upgrade option from the Professional Edition will be more expensive.
EAdams
Thank you for pointing this out. I've never bothered to learn what the different maps are used for, so I guess I don't need them smile:)
Actually, I only use FilterForge once in a blue moon to edit a family photo. For this purpose, I don't really even need the FF 4.0 Basic version. The only reason I was thinking of buying it was the sale price (and it being less expensive than an upgrade from FF3 Professional to FF4 Professional).
Though I don't use FilterForge a lot, I like to scroll through the filters and the filter gallery to admire the creative genius of the filter authors. You guys really rock!
For me there is an important difference between Basis, Standard and Professional, and is the render speed, as only the Professional version allows you have the multicore optimization so it can run as fast as possible, because on Basic and Standard it will be more slower as it will ONLY use just ONE core and so it will reduce the perfomance.
You already have FF 3.0 Professional so you are already using the fastest version and so you are used to get the perfomance of this version, and changing to the Basic from Professional will maybe make you feel that is more slower.
I can´t tell how much slower it will become.
Maybe if you use it little you will not care probably for taken more time to do the same with FF 4.0.
The other reason is that you will be able to use FF 4.0 filters that you can´t use with FF 3.0, maybe you can keep using FF 3.0 for the FF 3.0 filters and below as it is faster, and then use the Basic FF 4.0 only for filters that are for FF 4.0.
EAdams
Thank you, SpaceRay. I just discovered another reason to stick to the professional version. I just saw that the basic version can't handle bitmaps larger than 3000 x 3000. The photos out of my camera are larger than that smile:(
Sorry I made a mistake, and this is not true, as they will support and use ALSO dual core processors.
OH, yes, this is something also very important for me, although I did not put it as a reason because it depends totally on what kind of works and image you want to do.
EAdams
OK, I bit the bullet and ordered the Professional lifetime upgrade. This will save me loads of time because I won't have to agonize every time a new version comes out. I'm thinking that other people spend more money to go skiing, and at least I won't break any bones experimenting with FF. smile;)
21 unregistered users.
