Burpee
Posts: 14 |
I upgraded to FF4.07. I'm using the standard version.
The tiles/filters that I'm rendering look pixely to me. I did not seem to have the same problem in version 3. Is it just me or is there a difference. Also, is there a way to increase the resolution. These tiles are useless to me as is which means FF is useless to me right now. Help. |
| Posted: December 25, 2013 12:56 pm | ||||
Could you put a screenshot of what happens?
Could you explain what are you doing to get that "pixely" look?
Yes, is possible to do it using the Menu - New Image, But this will only work if you are using a filter belonging to the Texture categories or if you are not using an input image in the Effects categories. Do you the Menu --- View ---> Preview size in the reduced mode? Because this will ONLY allow to make 600x600 image and you can´t the resolution while in the preview reduced mode, you must change it to ACTUAL |
| Posted: December 26, 2013 4:19 am | ||||
21 unregistered users.
