If you have FF 4.0 and want to organize the filters that you have downloaded from the filter library is important that you use the "FAVORITES FOLDER" instead of the "Custom filters" folders because this way you will keep the filters as originals and will keep all the author information and keep the usage rank rewards for the author that have been working hard for making that filter.
If you organize the filters in the custom filter you will make a COPY of the filter instead and will loose all the author usage rank and possible rewards
For more information about the difference between both, please see this thread here
New Filter Manager FF 4.0: Custom Filters folder VS Favorites Folders
I think that it would be important that in the new Filter Manager features information would be more clear and avoid possible confusion on the difference between Custom Filters and custom Favorites Folders as they are not the same and can´t be used in the same way.
I would like to suggest that to avoid any confusion it would be better that it could be like I have put already in the link that is in the post above
14 unregistered users.
