yorvik
I am a complete beginner with Filter Forge.
I have just purchased 4 (basic)
Also downloaded addition free filter packs 2 > 6
I ran 2 and it installed as a separate 'item'.
How do I get the free packs to install into Filter Forge when I run their install Setup exec.
I think that you can´t use the "free filter packs" inside filter forge, because they do not have the same file format for installing them INSIDE filter forge, they are made to be outside of filter forge, if you want to have the SAME filters as the ones fr om the free filter packs you have to search them inside the filter library and download them from there.
Please read again the text attached to the Free filter packs
Freepacks are free Photoshop plugins based on the Filter Forge technology. Each freepack is centered around a different theme. Freepacks are distributed free of charge and don't have any time lim itations. All filters included in the freepacks are also available from the Filter Library, so users of commercial Filter Forge can benefit from them as well.
Filter Forge Basic gives you access to all the filters in the library, included those in the freepacks.
This means you can remove the freeepacks altogether, find these filters in the library and use them from within your Filter Forge 4 Basic.
yorvik
Thank you both SpaceRay & GMM for you prompt and informative answers.
Having to download separately from the library is probably even better than having to install the whole of the Freepacks, that way I can pick and chose what I want or need.
I assume that library downloads do not install but are used on an 'as needed' basis.
Thank you both again.
Regards
John.
24 unregistered users.
