Franfou
Franfou
hello Guys, im new to filter forge i would like to know if if possible to create seamless tiling image based on anykind of image and how to do it while make sure its matches perfectly when its repeated... i dont see many tutorials ressources..thanks !
Franfou
Franfou
..in order to create a perfect pattern...tx
infiniview
digital artist
Hello
Yes you can make any image into one that is seamlessly tiling. Although FF will not do all the work for you. Unless you use one of the filters that duplicates your image and overlaps and blurs the edges of your image. This can work for some things but not all. To make an image into one that is truly seamless you need to do that in photoshop or some other editor that allows you to make those fixes.
Make sure your image is square.
Go to PS-filters-other-offset, input a value -300 and +300 for a 600 px square image.
This will put all of your edges into the interior so you can clearly see how your edges will match up. Then you do and use whatever you can to make those edges come together. Clone brush, blur, paint whatever tools you may use to help you come up with a result that is acceptable to you. When you are finished reverse the offset filter and your ready to apply further affects in FF.
I hope this helps.
Well I remember a filter that was done specifically for this, it was made so you could take any photo or image and then it automatically mixed the edges of the photos and made a new seamless tiling, but the problem is that I do not remember the name or the author, sorry.
21 unregistered users.
