Ozmandias
Not sure what forum this belongs in so I just put it here.
It's pretty apparent that Carl will not be updating and re-releasing his incredible "Romancing The Gorilla" filter and there doesn't seem to be anything like it currently available so I was wondering if anyone has created or would consider creating a filter that produces essentially the same look and put it in the library for us to use?
If anyone does take this on, please make it compatible with FF3. smile:)
As far as i know, Carl does not want that his filter is uploaded avían, even a modified versión, and he is the only one that can decide to make it or not, as to have a similar filter, must s similar components, so it would have to be a variación of the same filter
If Carl allows that someone else could fix or make the filter as he would like to be done, it would be possible, although even then someone must be able to modify the filter as Carl wanted
Ozmandias
Are you saying that someone can't even attempt to make a similar filter? If he figured out how to make that effect, someone else could too and come up with something similar... not exact, but similar.
We can reverse engineer! smile:D
12 unregistered users.
