I have just discovered this page
FF 3.0 Script API for Noise and Blending Modes Althought I do not know how to script, I suposse that this examples can be used as script components without needing to add anything else to the script or do not need to make your own script to be able to use them, or I am wrong? I have not tried them yet. |
| Posted: September 5, 2013 6:14 am | ||
It's pretty handy. You got the z coord with the noise so you can do some smooth animation with it. Most of my uses of it were pretty utility. For example you can create a component that just produces that needed texture without the need of creating a huge tree. Just makes it compact.
The examples provided work as-is. You can edit the script, have a bit of messy fun, add additional controls if needed so on. But they're great starting points. |
| Posted: September 6, 2013 1:26 am | ||
27 unregistered users.
