RobWize
Hello FilterForge, I'm trying out the freepacks (found here: http://www.filterforge.com/download/) and I'm wondering how to install them for use in CS6E. I've recently upgraded CS5E and I know that in that version after installation a FilterForge section appeared under the "Filters" drop down menu. That doesn't seem to be the case in CS6E. I've installed Freepack 1 - Metals, opened the image I'd like to play with in CS6E and opened the Filters menu, but I don't see any "Metals" or "FilterForge" selections.
Is this something that can be used in CS6E? If so, where is it located after installation? If not, is this a stand alone only?
Hello RobWize. What OS version do you use?
Freepacks do support CS6, I'm not sure why your copy failed to install as a plugin. Please uninstall it and reinstall; if it fails again try placing the plugin files manually.
31 unregistered users.
