MKBreuer
MKBreuer
Filters: 47
Hy Morgantao!
I had some question about the FFCat Tool.
1. Is it only for 32bit or 64bit, too?
2. And where I can get it?
Just simple, but not simpler. (A.E)
The FFCat works also in 64 bit as I have Windows 7 64 bit and there is no problem, and also is because it does not need to be installed, it works directly fr om the icon of the application
Wh ere can you get it? Well there is two threads about this topic and there are links to download it
FFCat is out of beta!
Also in the FF Wiki there is a link FFCat
If there is not working you can see also this thread
Morgantao´s New tool for custom organizing and managing FF library!!!!
Although is very easy to use, also is useful that you see the video tutorial that Morgantao made and also read the instructions that are in this threads above
MKBreuer
MKBreuer
Filters: 47
Hy SpaceRay!
Thanks for the Links!
I have the same System and it works well!
It is a great Tool to order my FF Library!
It can be an Idea for the future FF-Aplications: a Customize-Favorite-Folder-System
Like in the that FFCat. That´s what i miss.
So thanks a lot!
SR, thanks for the help smile:)
I'm geting sloppy, not visiting FF forum nearly enough smile:(
20 unregistered users.
