James
James
Filters: 46
Ok so today im going to update filter forge on another computer, i have saved 144 filters to add to my other computers collection, im now wondering can i place filters in any folder i choose or will they only show up if they are placed in the correct folder?
plugsnpixels wrote:
PS: Where are the downloaded filters stored (for backup purposes)? I dug around the Filter Forge folder but didn't see anything obvious.
The path is as follows:
C:\Documents and Settings\YourUserName\Application Data\Filter Forge
To get there quick, open Filter Forge and press Ctrl+L (or click Filter > Locate File from the menu) -- this will lead you to the location of the Filter Storage.
voldemort
voldemort
Filters: 649
Since this is in beta I havnt worried about seperate cpu licensing yet so I have it installed on multiple computers 3 at work and 5 at home for instance Im on a mac now with it installed under paralles What I do is this
under the filter forge folder that Vladimir listed
there will be tow folders
My filters and System
My filters is where you copy --Your filters for the standard library
go into the system folder and then into the library folder This is where all fo the ffxml files should be listed copy them to the respective same folder on the other computer
They may not appear until you update the library structure by connecting online smile:)
James
James
Filters: 46
They may not appear until you update the library structure by connecting online Smile
Really smile:cry: but that computers offline always, doesn't the latest install update the structure. Or could i even just look on this computer (which is online) at the folder structure then copy it over to the offline pc if i put it on cd ect. Or would that not work?
+7 new in 7 days!
20 unregistered users.
