Desdinova
I just upgraded my GPU to an AMD Radeon RX 7900XTX. All the drivers are current and I'm running Vulkan API 1.3.292 and Vulkan Driver 2.0.317. OS is Win 10 Pro with 16 GBs of RAM. I've confirmed that Win is ignoring the system GPU and only using the AMD card. But I'm still getting the infamous error message:
"<class VPC::VException> Vulkan exception "limit exceeded" occured. Make sure that your graphics card drivers are updated to the latest version and that Vulkan 1.0.0.0 is supported on your machine."
Any ideas on what I can tweak or look at to resolve the issue?
Thanks!
Desdinova
Is there any reason to expect that this issue will be resolved any time soon? It seems a number of folks have the same complication and if Ultraforge can't figure out how to use the correct GPU, it seems simple enough to have the program simply give the user a choice on initial startup to manually direct it to the GPU that will work.
I don't have this issue with any other program so why can't Ultraforge be changed so it can load the same way other programs are?
fl0645
fl0645
Hello, how to install or repair Vulkan error with AMD RYZEN 5900XT, and, RADEON 6900XT.
Thank you
Vulkan 1.0.0.0
