Java10
Hello, it would be helpful to be able to watch several small tutorials in addition to the quick guide tutorials on how programming nodes can be used and in which situations.
Or is there a detailed user manual in addition to the quick guide?
It would be very helpful, if the examples were not made too complicated - i.e. with fewer nodes. For example, only 2 output images instead of 4. Everyone can then manage to turn the 2 images into 4 later, but the quick guide tutorials are a huge diagram of nodes and I don't understand, for example, how to use concat strings sensibly and what that is supposed to do in UltraForge?
I know what concat, boolean, strings etc. mean as programming elements - I just don't know what they are used for in the Ultraforge node editor and why they can help.
Thank you.
