Java10
Hi,
Is there a bug with the upscalers? Please take a look at the screenshot of the quick manual
Upscaler-Quick Manual
and compare it with mine in the screenshot. I'm missing all the parameters like Alpha, Tiled, Tile width, etc.
I have onle "Image"
What am I doing wrong?
Java10, what UF version do you use?
The one available on the website (build from June 27th) corresponds to the quick start manual and not to your screenshot.
If you're using the latest version please send the .ufo file to us.
Java10
Thank you for the quick response. Of course, that must be the problem.
I know that the developers have a lot of work, but it would be nice and desirable if interested parties or customers had an overview of the builds. I downloaded Ultraforge 1.001 at the end of February and was only able to test it in the last few days.
Of course, I checked the homepage before installing to see if there was a new version, but the download file is still called Ultraforge 1.0 Setup.exe and 1.001 is next to it. So for me as an outsider, there has been no further development and I don't have to replace the installation file - wrong thought, as it turns out.
I will test it in the next days. So I have to deinstall the old version - right?
Couldn't the build numbers be communicated clearly in the future?
Thank you for your help.
Thanks for the feedback, this has somehow slipped past us. We have updated the download page to show the latest build date.
Java10
Great, thank you very much. Will there be release notes available in the future so that comparisons can be made between the individual versions? At some point the bug fix for the upscaler would have been listed and I would have noticed it.
Is there a reason why the sub-release numbers x.001 are no longer specified?
Unfortunately no release notes at the moment, let's hope the devs will provide some in the future.
Technically all UF builds are version 1.001 which makes little sense considering the amount of improvements introduced since the release.
Java10
Thank you for the quick and detailed answers.
