Java10
Hi,
I installed Ultraforge 1.01 Trail Version a few days ago and during installation I wanted to set a different directory for the stable diffusion folders (checkpoints, LoRAs).
When I then started Ultraforge, the program crashed every time I started it.
The only solution was to reinstall it and leave the default installation path.
Suggested solutions:
a) either you are not offered the option to change the default directory or
b) this bug will be fixed by you, so that Ultraforge finds a different folder path.
Thanks for your reply.
