BillB
Hi. I followed the guide on getting LoRAs from the CivitAI website. I put them in the C:\Ultraforge\SD 1.5 Extras\LoRA folder. Nothing happened when I ran Ultraforge, they didn't get loaded. What am I missing?
Thanks
The reason may be in the log file. Please check out C:\Users\username\AppData\Local\Temp\Ultraforge.log
What particular LoRA are you using? Most of the CivitAI LoRAs are compatible but not all of them.
cabaer
I have the same problem. I am looking at C:\Users\username\AppData\Local\Temp\Ultraforge.log. What should I be looking for? How do I fix it?
Java10
Hi cabaer,
which LoRA do you use?
